I want to block my son's internet access from WAP3205, how could I set it up?
[Deleted User]
[Deleted User] Posts: 1 image  Freshman Member
  • [Deleted User]
    [Deleted User] Posts: 6 image  Freshman Member
    @Angelina
    If you had a Zyxel router which supports ONE Connect app, you could enter in the app, find the network-map, then you could see the mobile device of your son. Just tap it to block.
