Sharing dhcp history between usg300 and usg2000
hansjalbertsson
hansjalbertsson Posts: 34
edited April 2021 in Security
Can dhcp tables be transferred between a usg2000 and a usg300, so the usg300 can seamlessly take over dhcp management from the 2000 including lease times and ip/mac binding?
  • hansjalbertsson
    I shall try this. But the other way around, of course. I want to move data from the 2000 to the 300.
    Couldn't the usg300 be set up as a HA partner to the usg2000, and then we could force a failover when we need to work on the usg2000?
  • Blabababa
    Blabababa Posts: 151
    5 Answers First Comment Friend Collector Fifth Anniversary
    I think the HA can only run between "the same models" or there will be port setting conflict if users want to do HA between different models that have different port number (e.g usg50 usg300).
  • hansjalbertsson
    So if you stay within the ports common to both models, like ge1 to ge6 for usg300/2000, it might work?
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034
    Hello hansjalbertsson,
    For this case,
    try the steps which I mentioned on previous post first, and if any question please let me know.
    Secondly, for the question of HA,
    The conditions of doing HA are that two usg of the same model, with the same FW version and with the same configuration, so USG2000 cannot do HA with USG300.
    Charlie
Security Highlight
