[090902]LED Light Suppression Request
Tri
Even though the LED's on Multy are pretty low, in a bedroom where I have it, it actually lights up the entire room with its glow. Are there any options to suppress the LED and only turn back on blinking if there are link/backhaul issues or during configuration?
@Tri,You can follow the steps to disable LED.1. Tap the "Menu" icon in the top-left corner on the screen.2. Tap "My Multy" in the menu.3. Select the Multy X device.4. Turn off LED.
- 588 USG FLEX H Series
- 477 News and Release
