[091201]Couldn't set up the 2nd Multy X
ocethan8
ocethan8 Posts: 4 image  Freshman Member
edited September 2017 in Archive 2017-2020
I'd tried many times to reset, and setup on the 2nd Multy X, and couldn't add it to the network. It said the distance was too far from the first unit, so I'd changed to several locations and put it even around the first unit; it still showed "too far" when it should be "too close." Therefore, I'm not sure if the measurement is accurate to detect the distance between these two units. In result, I still couldn't set up the 2nd unit to the network. Please advise. thanks.
  • Zyxel_Support
    Zyxel_Support Posts: 436 image  Zyxel Employee
    @ocethan8,
    What's the LED status of 1st and 2nd node during the install process regarding 2nd node?
    We will release a new app version of Multi X this Wednesday. Please kindly use new version to verify this problem again.
