[091407]Change the DHCP of the two Wirless SSID
pancho35m
Hey,
i like the idea of the two DHCP Server for Wireless and Guests.
But i like to see an expert wizard or a question in the normal installation wizard if you want to use these IP Ranges or not. If not you have to change it by yourself.
Both SSIDs or interfaces are bridge so i can reach my internal devices but they are in a complete different IP Range.
And i do not want to manage two or three IP Ranges in my internal network.
Thanks a lot
BR
Pancho
Thanks a lot
BR
Pancho
Private network (Main SSID) is different with Guest WiFi.
There are two DHCP pool, one for Private network, another for Guest WiFi.They cannot communicate each other.0 -
Yeah ok understand.
But my internal LAN has the 172.16.138.0 / 24
and if i set up the multy x then i have for my wireless the ssid 192.168.212.0/24
and i do not want to manage 2 IP Ranges and i do not want to change my internal LAN.
If i setup my environment from zero then it is ok, But not if i have an existing LAN environment.
For example i cannot find the multy x devices on the dhcp table list.
So just think about it to change the Setup wizard or use an expert wizard where you can change the IP Adress of the multy x
BR
Pancho0 -
@pancho35m,
Multy X will support bridge mode around Q4.1 -
ok sounds good. We will wait and check again when it will be launched0
- 588 USG FLEX H Series
- 476 News and Release
