[091408]The Guest wifi is there a Layer2Isolation?
pancho35m
Hi Team,
is in the guest wifi a layer2isolation? If not the user from the IP Range 192.168.141.x can ping devices in the ip range 192.168.212.x and from there my internal lan which comes from the Firewall?
BR
Pancho
BR
Pancho
Guest WiFi is not a layer2isolation.When wireless client is connected to Guest WiFi:- It only can access Internet.- It cannot ping 192.168.212.x.- It cannot see/access your internal LAN and device.0
Ok Thanks i will check this0
- 588 USG FLEX H Series
- 477 News and Release
