[092002]Guest Wifi shouldn't be show "disable" when it is not active
Theo1975
Guest Wifi shows "disbale" if the Guest Wifi is not enabled
Same when it is active it shows "enable"
Shouldn't it be vise versa?
Android 1.1.8.170913
Thanks for your reported.We will modify the status of Guest WiFi and implement in the future version.0
Sounds good, thanks
- 588 USG FLEX H Series
- 476 News and Release
