[092205]Getting Access also by Webbrowser
pancho35m
pancho35m Posts: 72 image  Ally Member
Fifth Anniversary
edited September 2017 in Archive 2017-2020
Hi Team,
i really like the Idea of the Aurora Team that you can also use the webbrowser instead of the APP.
The installation of the devices should only work by app not by webbrwoser.
But afterwards checking the Speed limit or setting up the time scheduler and maybe monitoring should also work by web browser.
Just think about it
BR
Pancho
  • Theo1975
    Theo1975 Posts: 45 image  Zyxel Employee
    Third Anniversary
    Totally agree, also it makes easier for support Agents to see what customer has done so far/check states and history (f.e. via Teamviewer).
  • Zyxel_Support
    Zyxel_Support Posts: 436 image  Zyxel Employee
    Currently, we don't have the plan to implement this feature.
  • pancho35m
    Fifth Anniversary
    Ok thanks good to know
  • DrPepper
    DrPepper Posts: 35 image  Freshman Member
    Unfortunate.
  • pancho35m
    Fifth Anniversary
    For example: If the App crashes or the system is unavailable with the app you have to use a second option like using the webbrowser. Just think about it.
    I can understand not have this on Aurora but Multy is completly different and it is important to have acces to the system however with app or browser or by telnet.
    Just think about
    BR
    Pancho
  • Zyxel_Support
    Hi All,
    Sorry for the inconvenience.
    This is current design and Multy X has not any plan to support Getting Access also by Web browser.
