[092205]Getting Access also by Webbrowser
pancho35m
Hi Team,
i really like the Idea of the Aurora Team that you can also use the webbrowser instead of the APP.
The installation of the devices should only work by app not by webbrwoser.
But afterwards checking the Speed limit or setting up the time scheduler and maybe monitoring should also work by web browser.
Just think about it
BR
Pancho
Just think about it
BR
Pancho
Totally agree, also it makes easier for support Agents to see what customer has done so far/check states and history (f.e. via Teamviewer).
@pancho35m and @Thorsten,Currently, we don't have the plan to implement this feature.0
Ok thanks good to know0
Unfortunate.1
For example: If the App crashes or the system is unavailable with the app you have to use a second option like using the webbrowser. Just think about it.
I can understand not have this on Aurora but Multy is completly different and it is important to have acces to the system however with app or browser or by telnet.
Just think about
BR
Pancho1 -
Hi All,Sorry for the inconvenience.This is current design and Multy X has not any plan to support Getting Access also by Web browser.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
