Two channels for Keenetic 4G II
Good afternoon!
In stock ZyXEL Keenetic 4G II. It is necessary to connect to it simultaneously two Internet channels:
1 - Wired into the WAN connector.
2 - 4G modem with a permanent IP address for remote administration of the router.
It requires that the default is a wired Internet channel, and when you connect to the router remotely, it goes to work from the modem.
It is not possible to manually change the priority of connections, because administration is carried out remotely!
Tell me, please, such it is possible to implement means of this router on the official firmware or an additional router for physical separation of channels is required.
Hi @lexyz,
Welcome to Zyxel community!
For the Keenetic product, please refer to the link below to contact the local support directly.https://www.zyxel.com/ru/ru/contact_us/contact-us-overview.shtml
Hope it helps.
Jason0 -
Thank you so much. But this impossible...
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
