Mounting USG210
Jarno_Smits
Jarno_Smits Posts: 23
image  Freshman Member
edited April 2021 in Security
good morning,
bought a USG210, official this type isn't for wall mounting.
but are there some people here, that mount a USG210 to a wall already?
i want to mount it vertical to the wall,(with custom made clips ) around the USG210 there is enough  airflow.
I have a USG60 and noticed this type doesn't get hot, when wall mounted, If this is also with the USG210 then i think wall mounting isn't a problem.
kind regards,
Jarno Smits
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034
    image  Zyxel Employee
    Hello Jarno Smits,
    For the USG210, we suggest it should place on the table or rack(the original design), however, I think USG210 can be mounted on the wall if you keep enough airflow for ventilation hole of device,
    Charlie
  • Jarno_Smits
    Hi Charlie,
    Thank you for the answer, i,m gonna try the wall mounting and monitoring the temperture, there is enough airflow at the ventilation hole.
  • Jarno_Smits
    Hi Charlie,
    Some feedback.
    Zywall is working for a month now, wall mounted, it works without a problem, temperature is ok.
