Can't establish VPN-connection Win10<->USG60W
poberl
poberl Posts: 3 image  Freshman Member
edited April 2021 in Security
I recently installed a USG60W and now fail to setup VPN correctly.
My goal is to allow tunneling into the LAN via VPN using Windows 10's built-in VPN client.
The firewall is behind the modem given to me by my ISP:
Internet
185.50.xx.yy (WAN) - A1 WLAN Box ADB VV2220 - 10.0.0.138 (DMZ)
10.0.0.2 (WAN1) - ZyXEL USG60W - 192.168.0.20 (LAN1)
When trying to connect, Windows says:
While the firewall's log says:
It seems to me, it's repeatedly rekeying (whatever that means):
VPN connection and gateway were created by the quick setup wizard and are configured as follows:
Does anyone know, what the problem might be or how to solve it?
I appreciate any kind of help!
