Can not ping local computers
We have 3 x switch GS2200-48 and router USG100. Yesterday we have power maintaince and after power came back just one computer isnt able to ping other computers. It can go to internet but can not ping any local pc except switch and router.
I tried to put it on different port on switch, change cables, disable firewall, change from dhcp to static ip, disable antivirus, clear arp table but still can not ping local computer.
any idea?
#Biz_Switch_January
#Biz_Security_January
any idea?
#Biz_Switch_January
And restart proprely this only one computer don't resolve the default ?0
Interesting, "just one computer" has this problem?? how about try with an USB network adapter to cross check?0
Hi @djpiky,
You may verify the followings on your GS2200 switch:- Do you enable Port Isolation on the switch except for uplink port(the port which goes to the Internet)? You may go to "Advanced Application -> VLAN -> VLAN Port Setting" to check.
If yes, you may disable it and try again. - If there is an ACL configuration on the switch to block the traffic from the computer to other local computers?
- Make sure all your local computers have already disabled Windows firewall.
0 - Do you enable Port Isolation on the switch except for uplink port(the port which goes to the Internet)? You may go to "Advanced Application -> VLAN -> VLAN Port Setting" to check.
I figured out, if i connect other computer on same port, everything is working. So i belive that problem is on computer or maybe something wrong with arp tables?
I also figured out that i can ping computers which are on same switch connected, but i can not ping computers which are connected on any other switch. As i said, if i connect different computer on same port, everything is working OK. Any idea?
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 456 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
