USG20W-VPN new clients belong to the wrong interface
When machines in our network are turned off and started again our USG20W-VPN will often show them in the arp-table as belonging to the "wan" interface (the "show arp-table" command) despite being in the "lan1" interface.
Currently we resolve the problem manually by either pinging the machine from the router or having to issue a command such as "tracert 8.8.8.8" which seems to "fix" the arp table.
While the address is in the wrong interface it has no access to the internet.
This is the result of the show arp-table command. Please note that 192.168.10.143 doesn't have access to the internet and that 192.168.10.8 is classified both as lan1 and wan at the same time (it should be only in lan1).
We need help with resolving this.
thanks in advance,
Router> show arp-table
Address HWtype HWaddress Flags Mask Iface
192.168.10.4 ether 00:1d:09:28:8a:1d C lan1
192.168.10.153 ether 40:b4:cd:69:03:7d C lan1
192.168.10.106 ether 94:65:2d:a3:76:8d C lan1
192.168.10.143 ether 98:de:d0:05:42:54 C lan1
192.168.10.105 ether b8:ae:ed:75:2c:ef C lan1
192.168.10.123 ether e0:d5:5e:0d:0f:7b C lan1
192.168.10.151 ether b8:ae:ed:73:1f:dd C lan1
192.168.10.104 ether b8:ae:ed:73:66:09 C lan1
192.168.10.132 ether ac:0d:1b:f8:7d:c9 C lan1
192.168.10.143 ether 98:de:d0:05:42:54 C wan
192.168.10.150 ether f8:63:3f:58:c2:71 C lan1
192.168.10.140 ether 78:24:af:3c:a5:91 C lan1
192.168.10.130 ether 94:de:80:77:15:67 C lan1
192.168.10.8 ether d8:50:e6:d3:0d:00 C lan1
192.168.10.129 ether 10:c3:7b:4d:fb:b0 C lan1
192.168.10.157 ether 1c:1b:0d:17:8c:5d C lan1
192.168.10.110 ether 30:5a:3a:09:1d:d0 C lan1
192.168.10.166 ether b8:ae:ed:73:65:f2 C lan1
192.168.10.8 ether d8:50:e6:d3:0d:00 C wan
192.168.10.100 ether 40:d3:ae:70:c1:4c C lan1
192.168.10.203 ether 00:17:61:12:3a:85 C lan1
thanks in advance,
Hello ogentech,
To analyze this case,
please private message the packet of wan and lan1 to me, when issue occur.
Moreover, since the IP: 192.168.10.143 and 192.168.10.8 are classified both as lan1 and wan, I would like you to double confirm the topology which is not loop. (Please share the topology of this case).
Charlie0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
