Is there any way to change MTU(Maximum Transmission Unit) on GS1900-8?
nospherato
Hi all,
I recently bought a ZyXel GS1900-8 Switch and now I have got a little problem:
I need to change my MTU to 1412 (using hybrid internet connection and can not change it router sided).
In the webinterface (newest firmware) I only found the option to set 802.3 maximum fame size, but not setting a custom frame size.
Is there any way to configure a custom frame size per port (or global for all ports)? Perhaps via CLI/telnet?
Best wishes
nospherato
Best wishes
nospherato
#Biz_Switch_February
Hi @nospherato,
I find a document from Zyxel KB that GS1900 can't modify the MTU via WebGUI or SNMP.
You may refer to this link: https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=016101&lang=EN
GS1900-8 already support Jumbo frame 9K, there is no need to change MTU on the switch.
Why you need to customize the MTU?
Thanks.
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
