Modifying network masking on SSL VPN.
PauloJrMcz
I have a USG110, I need a help, I believe that simple, come on, I have a 192.168.0.0/23 network with 255.255.254.0 network mask, I configured the SSL VPN, however when I connect the client it always assigns the mask 255.255.255.0, forcing me to have to modify it manually.
Remember that the mascara of the lan interface of the router is also like 255.255.254.00 -
Hello PauloJrMcz,
Thanks for reporting. we confirmed this is an issue. We may fix this issue in the future release.
Moreover, when the symptom occur, I just curious purpose that why you need to modify the mask? Does SSL VPN does not work or..?
Charlie0 -
Hello PauloJrMcz,
We had confirmed this issue. However, since this issue will not lead to any malfunction on the device, we need to evaluate our plan about this case.
Charlie0
- 588 USG FLEX H Series
- 476 News and Release
