Trying to connect two identical subnets using two Zywall 1100's
Hi all, I'm a noob to all of this so please be gentle. I have two physical locations with the same subnet, namely 192.168.2.0/24. I have a need to have two devices (one at each physical location) to be able to see each other through a remote link. The devices discover each other through broadcast traffic.
Using my Zywall 1100's on each side, I need to be able to have the Zywalls connect so that the two devices appear to be on the same subnet. For the sake of discussion device1 in location1 has a local IP address of 192.168.2.100 and device2 in location2 has a local IP address of 192.168.2.210. How do I connect the two locations so that they can see each other as if they were physically in the same subnet?
Thank you in advance for any help you can provide!
#Biz_Security_February
It seems you need the VPN to make two device can communicate with each other.
Here is the example:
https://businessforum.zyxel.com/discussion/551/an-example-of-site-to-site-vpn#latest
Thank you for your response. That example shows two different subnets being connected. I have successfully done that using a VPN connection. That example shows a two subnets 10.10.10.1 and 192.168.20.1 being connected. I have two devices that absolutely have to be on the same subnet otherwise they won't work.0
- 217 Nebula Ideas
- 573 USG FLEX H Series
- 297 Service & License
- 472 News and Release
