How can I add a Wifi device which only supports WPS?
TOConsulting
I have a business network with WAC6103D-I and NWA5123-AC. These accesspoint are managed with the USG60. I have wifi printer which supports only Wifi WPS configuration. How can I add these printers into the wifi?
Hi @TO_Consulting,
WAC and NWA series AP doesn't support WPS, but NBG series AP router support it.
For your reference:
ARMOR Z2 AC2600 MU-MIMO Dual-Band Wireless Gigabit Router - NBG6817 with 3x3 antenna
https://www.zyxel.com/products_services/armor_z2.shtml?t=p#productDetailTab5
AC2200 MU-MIMO Dual-Band Wireless Gigabit Router- NBG6815 with 2x2 antenna
https://www.zyxel.com/products_services/AC2200-MU-MIMO-Dual-Band-Wireless-Gigabit-Router-NBG6815/specifications
The NBG series AP router can be change from router mode to AP mode. It can be also support WPS for your printer.
Kathy0 -
Since the WPS have vulnerability for a long time. And not sure if every vendor had patch for it.
https://en.wikipedia.org/wiki/Wi-Fi_Protected_Setup
I would recommend to create another dedicated SSID with MAC-authentication for your printer.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
