nwa5123-ac have smth like schedule-run cli command?
vrb_dst
vrb_dst Posts: 3 image  Freshman Member
edited May 2024 in Wireless
Hi, all.
I'm using NWA5123-AC with V5.20(AAZY.3) firmware on it.
Can't find any "scheduler" on web-interface(and in CLI) to run script.
Any thoughts where is it?
#Biz_WLAN_February
  • Zyxel_Sally
    Zyxel_Sally Posts: 32 image  Zyxel Employee
    @vrb_dst
    Thanks for you choosing Zyxel product.
    There are two way introduce how to  configure scheduler for you refer:
    Here is SSID scheduler via WEB GUI.
    Please go to CONFIGURATION -> Object -> AP Profile -> SSID -> edit the profile -> Enable Schedule SSID.
    If you want to configure it via CLI, here it is.
    Router> configure terminal
    Router(config)# wlan-ssid-profile < ssid profile name>
    Router(config-wlan-ssid default)# ssid-schedule
  • Zyxel_Sally
    @vrb_dst
  • vrb_dst
    That's great, but i wana use a script for reboot with scheduler. So seems that's not what i need.
  • Zyxel_Sally
    @vrb_dst
    Please follow the below steps to enable the schedule to reboot the device regularly.
    1. Create a shell script
        Open a notepad file, and key in “reboot”. Save it as reboot.zysh.
    2. Upload the file to MAINTENANCE -> File Manager -> Shell Script
    3. Apply the CLI via console or SSH.
        Please refer to the KB. Here is the link.
        http://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=014180&lang=EN
        Router(config)# schedule-run 1 <script file (*.zysh)> <daily, monthly, weekly> <time,HH:MM>        Router(config)# write
            No schedule run.
            Router(config)# no schedule-run 1
  • vrb_dst
    there is no schedule command )
  • Nekan
    Nekan Posts: 1 image  Freshman Member
    I'm digging up an old post. i had the same problem i solved it by creating a bash script :
    #!/bin/bash
    USER=your_username
    PASS=your_password
    ADDR=nwa_address
    timeout 30 sshpass -p $PASS ssh -oStrictHostKeyChecking=no $USER@$ADDR << EOF
    reboot
    EOF
    # End of script
    It only remains to add the script to the crontab.
    Example :
    # reboot at 2am
    0 2 * * * root /path/to/the/script
    Enjoy :)
  • samuel07
    samuel07 Posts: 1 image  Freshman Member
    edited January 2021
    Nekan said:
    I'm digging up an old nj post. i had the same problem i solved it by creating a bash script :
    #!/bin/bash
    USER=your_username
    PASS=your_password
    ADDR=nwa_address
    reboot
    EOF
    # End of script
    Example :
    # reboot at 2am
    Enjoy :)
    Hey thanks @nekan buddy,
    I was getting the same issue and have resolved my issue through your scripts.
  • matt_donovan9
    matt_donovan9 Posts: 1 image  Freshman Member
    @vrb_dst
    Hi, all.
    #Biz_WLAN_March
