Cant see my 5G spot on NBG6604
LastFear13
I bought this router and did all the setup. I see my 2,4Ghz band on list, but my 5Ghz band wont show on list although i can configure it. I checked if my device supports it and it does, also I updated drivers.
#Router_May
#Router_May
Hi LastFear13,
Here are some questions wants to confirm with you.
// I see my 2,4Ghz band on list, but my 5Ghz band wont show on list although i can configure it.What is 5Ghz channel? Do you enable 5Ghz?// I checked if my device supports it and it does.What is the model name of your device? Do you try to use another device which supports 5Ghz?// also I updated drivers.V1.00(ABIR.2)C0?May I know do you try to reset NBG6604? Is it still get the same problem?0
- 433 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 115 Nebula Status and Incidents
- 6K Security
- 388 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
