GS1900-10HP hacked :\
GabrieleMax
When I try to connect to my GS1900-10HP it sends me a file named
if [ -f /mnt/web/modules.tar.lzma ];then
mount -t ramfs /dev/mem3 /lib/modules/
cp /mnt/web/modules.tar.lzma /lib/modules/
cd /lib/modules/
unlzma modules.tar.lzma
tar -xvf modules.tar
rm modules.tar
cd -
fi
After a port scan I have:
oot@Server01:/home/gabriele# nmap -sS -P0 -sV -O 192.168.1.230
Starting Nmap 7.70 ( https://nmap.org ) at 2018-08-04 16:12 CEST
Nmap scan report for 192.168.1.230
Host is up (0.020s latency).
Not shown: 998 closed ports
PORT STATE SERVICE VERSION
80/tcp open http uc-httpd 1.0.0
554/tcp open rtsp H264DVR rtspd 1.0
MAC Address: XX:XX:XX:XX:XX:XX (ICP Internet Communication Payment AG)
Device type: general purpose
Running: Linux 2.6.X|3.X
OS CPE: cpe:/o:linux:linux_kernel:2.6 cpe:/o:linux:linux_kernel:3
OS details: Linux 2.6.32 - 3.10
Network Distance: 1 hop
Service Info: Device: storage-misc
OS and Service detection performed. Please report any incorrect results at https://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 35.79 seconds
Now how can I fix it?|
GabrieleMax
#Biz_Switch_Aug
Yq2b40+w, when I open it I have:
Index of /mnt/web/
modules.tar.lzma
pkg_clean.sh
unpkg.sh
The first file is a compressed file and inside of it I have a lot of files with *.ko extension something like codec.ko and decoder.ko, really strange ![]()
In the second file I have:
rm -rf /lib/modules/*
umount /lib/modules/
fi
cd /lib/modules/
rm modules.tar
cd -
fi
GabrieleMax
#Biz_Switch_Aug
Hello @GabrieleMax
I'm curious how you found the problem.
Did you try to remove all other devices connected firstly and then connected PC with GS1900?
I suspect if it is possible that the files were actually coming from other devices, for example, one of other servers, instead of GS1900.
Could you have a try to remove all other devices connected with GS1900 and then connect PC again (only one PC) to see if there is still the same problem?
Ryan
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
