USG60W - Package Capture - Host-IP incorrect sorted by Object
Hi together,
during the Update to 4.30 the sorting of the Host Obejct in the Capture Screen Maintenance -> Diagnostics -> Packet Capture
Check the pulldown menue "Host IP" in the "Filter Section" if the alphabetic sorting is incorrect...
Can this reproduced by ZYXEL ?
Best regards
Christian
Best regards
Christian
Hello ChristianG,
We already identified this issue, so we will fix this issue in the future release.
Charlie0 -
Hello Charlie,
there is another incorrect-sorting on the USG....
can you double check, when you are navigate to Configuration / WWW / Admin Service Control.
Edit an existing rule -> open the "zone" filed and please check the alphabetic sorting.
Thx forward
Christian
Hello ChristianG,
Charlie
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
