USG 50 VLAN Setup
dcgtechnologies
Hi All. I have a Zyxel USG50 Firewall. I am trying to configure the routing for VLAN 10. Currently all workstations and servers are on VLAN1, but my end goal is to move all devices to VLAN 10, but currently I am only able to ping the Default Gateway of VLAN 10 and not able reach the test machine I have on the VLAN10 subnet. The difference between the VLAN's 20 and 30 are that they are using the Zyxel as there DHCP server whereas the VLAN10 will have a Windows DHCP server on it. I have two Cisco Switches and all communications work fine with all the VLANS. I can reach all devices on all VLAN's accept VLAN10 as that VLAN is not using the DHCP server function that is available. From VLAN1 All devices have a network IP address of 192.168.1.x with a Default Gateway of 192.168.1.1.
Currently the VLANS are configured as follows:
VLAN 1 - Management Network - 192.168.1.x
VLAN 10 - Users Workstations - 192.168.2.x
VLAN 20 - Users Wifi - 192.168.3.x
VLAN 30 - Guest Network - 192.168.4.x
It sounds to me I might have a routing issue on the Zyxel as I can not get to devices on VLAN10 without using the zyxel DHCP server. Any ideas on how to fix this? Thank you all in advance.
The windows DHCP server on VLAN10 is listing the gateway as 192.168.2.1 of the USG gateway?
can the other test machine ping the gateway?
Do you have IP/MAC binding disabled on VLAN10?
Have you tried disabling the firewall to see if all works fine?
@PeterUK , thanks for your sharing.
Hello dcgtechnologies,
To analyze this case, please check and collect below information.
1. Does the gateway of windows DHCP server be configured 192.168.2.1 which is the same as USG's gateway?
2.Disable the firewall and IP/MAC binding and test again.
3. Please collect the packet for checking further when you ping the test machine.(Please private message the packet with source IP and destination IP to me)
Go to Maintenance>Diagnostics>Packet Capture>Select Vlan10>Press Capture.
after that press Stop and download packet from "Files".
Please also private message the configuration to me for checking purpose.
Charlie
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 496 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
