GS-2210 ssh fails on MacOS openssh "ssh_dispatch_run_fatal: Connection to 10.0.99.250 port 22: DH
macpro:~ warwick$ ssh admin@10.0.99.250
ssh_dispatch_run_fatal: Connection to 10.0.99.250 port 22: DH GEX group out of range
Cause: too few bit settings for DH (Diffie Hellman)
Workaround: use -o in cli as: "-oKexAlgorithms=diffie-hellman-group1-sha1"
ssh -oKexAlgorithms=diffie-hellman-group1-sha1 admin@10.0.99.250
Request:
- maybe you could resolve upstream in the gs2210 in next V4.5x ?
Diagnostics : via ssh -vv
macpro:~ warwick$ ssh -vv admin@10.0.99.250
OpenSSH_7.4p1, LibreSSL 2.5.0
debug1: Reading configuration data /etc/ssh/ssh_config
debug2: resolving "10.0.99.250" port 22
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to 10.0.99.250 [10.0.99.250] port 22.
debug1: Connection established.
debug1: key_load_public: No such file or directory
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.4
debug1: Remote protocol version 1.99, remote software version OpenSSH_3.9p1
debug1: match: OpenSSH_3.9p1 pat OpenSSH_3.* compat 0x01000000
debug2: fd 3 setting O_NONBLOCK
debug1: Authenticating to 10.0.99.250:22 as 'admin'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,ext-info-c
debug2: host key algorithms: ssh-rsa-cert-v01@openssh.com,rsa-sha2-512,rsa-sha2-256,ssh-rsa,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ssh-ed25519-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,aes192-cbc,aes256-cbc
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,aes128-cbc,aes192-cbc,aes256-cbc
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: host key algorithms: ssh-rsa,ssh-dss
debug2: ciphers ctos: aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,arcfour,aes192-cbc,aes256-cbc,rijndael-cbc@lysator.liu.se,aes128-ctr,aes192-ctr,aes256-ctr
debug2: ciphers stoc: aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,arcfour,aes192-cbc,aes256-cbc,rijndael-cbc@lysator.liu.se,aes128-ctr,aes192-ctr,aes256-ctr
debug2: MACs ctos: hmac-md5,hmac-sha1,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: MACs stoc: hmac-md5,hmac-sha1,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: reserved 0
debug1: kex: algorithm: diffie-hellman-group-exchange-sha1
debug1: kex: host key algorithm: ssh-rsa
debug1: kex: server->client cipher: aes128-ctr MAC: hmac-sha1 compression: none
debug1: kex: client->server cipher: aes128-ctr MAC: hmac-sha1 compression: none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(2048<7680<8192) sent
debug1: got SSH2_MSG_KEX_DH_GEX_GROUP
macpro:~ warwick$
Warwick
Hong Kong
Hi @warwickt,
Openssh starts using "sha2" in the recent version, so you will see the error message and use the workaround to use "sha1" to access the switch.
It will be enhanced in the firmware version V4.50 on GS2210 series.
Note: Because of the security concern, firmware V4.50 will support "sha2" but no longer support "sha1".
Hope it helps.
Jason1 -
@Zyxel_Jason sounds good, when is your V4.50 ?0
Hi @warwickt,
We have a good news for you. The firmware version V4.50 for GS2210 release schedule is accelerated to the week of 1/29/2018. Hope you like the Chinese New Year present and happy new year.
Zyxel Switch Team0 -
Hi Zyxel_Albert, thanks mate! thats sounds good. Looking forward to the CNY gift!..
Thanks again Zyxel lads!.
Warwick
Hong Kong0
- 384 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 79 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 909 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 898 Nebula FAQ
- 415 Security FAQ
- 234 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
