my GS2210-8HP lost the PoE function over night
Hi
I use my GS2210-8HP to power two NWA1123-AC-Pro and over night the power was gone. If I inject the power via an extenal PoE power supply everything works perfekt.
I switched ports but I got the save effect.
Any idea what can cause the problem?
many thanks
Kind Regards
alex
#Biz_Switch_Dec_2018
many thanks
Kind Regards
alex
Can you capture the "PoE Status" and "System Log" of your switch for us?
Please specify which port your NWA1123-AC-Pro is connecting.
Moreover, do you have any "time range" configuration on the PoE ports?
Sincerely,
Zyxel_Lucious0
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
