USG20W-VPN Configure wlan in expertmode?
Hello Andreas,
Please follow the below way to configure the local(Internal) AP.
Go to AP profile>SSID> configure the pre-shared key
Go to SSID List to configure SSID's profile name and SSID.
On the Radio, you can create the profile for 5G or 2.4G
Move to Wireless>AP management, you can select which frequency you want to connect and choose SSID profile.
Note: On the USG20W-VPN, you only can select one frequency at one time.
Charlie
Thanks, i totally missed the AP Profile under objects.0
Charlie
Thank you for the information about the Zywall wireless setup. It was helpful I was able to configure and connect. Awesome!!
Hi @Darling ,
Welcome to Zyxel community. Just feel free to ask question here.😎
I have a USG40W. Is it me or is it not possible to create 5GHz wlan in expert mode?0
Hi @S0krates,
The build-in WiFi (Local AP) on USG40W only support 2.4GHz.
For managed AP which supports 5GHz, follow the guide below to configure 5GHz radio profile and Radio 2 setting.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
