USG20W-VPN Configure wlan in expertmode?
Hello Andreas,
Please follow the below way to configure the local(Internal) AP.
Go to AP profile>SSID> configure the pre-shared key
Go to SSID List to configure SSID's profile name and SSID.
On the Radio, you can create the profile for 5G or 2.4G
Move to Wireless>AP management, you can select which frequency you want to connect and choose SSID profile.
Note: On the USG20W-VPN, you only can select one frequency at one time.
Charlie
Thanks, i totally missed the AP Profile under objects.0
Charlie
Thank you for the information about the Zywall wireless setup. It was helpful I was able to configure and connect. Awesome!!
Hi @Darling ,
Welcome to Zyxel community. Just feel free to ask question here.😎
I have a USG40W. Is it me or is it not possible to create 5GHz wlan in expert mode?0
Hi @S0krates,
The build-in WiFi (Local AP) on USG40W only support 2.4GHz.
For managed AP which supports 5GHz, follow the guide below to configure 5GHz radio profile and Radio 2 setting.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
