HTTPS wan to lan
Forward port 443.
Thank you for the reply!
Can I use different https ports? I've got more than one server.
If your router supports port translation, you can forward any port to port 443 on your server, but if you want to access it from outside, you'll have to specify the port:orYou'd better use a port above 1024, else your ISP might get worried.0
Thank you!
I'll try next year
You may check the this thread from Biz forum.
https://businessforum.zyxel.com/discussion/comment/1480#Comment_1480
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 684 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
