switch on PoE for each port via SNMP
Hi Alberto
GS1900-24HP is an entry level switch and it does not support this function.
Therefore, we have to switch on and off PoE via web GUI.
If you want to switch on and off PoE via SNMP, maybe you can consider buying a higher level switch, such as GS2210.
GS2210 supports this function.
Derrick
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
