USG40: disable the web authentification on the WAN side, but keep it internally (LAN)
If your wanting to do SSL VPN you will be allowing WAN to ZyWall on port 443 is this what your doing?
I have a IPSEC VPN configured from Office to Branch. I don't know which port that is to be honest.
What I do know, something in the policy rule WAN to Zywall is disabling my vpn connection when I disable it.
So you need a rule for WAN to Zywall with service ports for the IPSEC VPN so you don't allow all service ports.
You could do it as:
first rule WAN to Zywall deny to service HTTPS
second rule WAN to Zywall allow all
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
