USG40: disable the web authentification on the WAN side, but keep it internally (LAN)
2»
    PeterUK Posts: 4,267 image  Guru Member
    If your wanting to do SSL VPN you will be allowing WAN to ZyWall on port 443 is this what your doing?
  • ictforever
    ictforever Posts: 15 image  Freshman Member
    I have a IPSEC VPN configured from Office to Branch. I don't know which port that is to be honest.
    What I do know, something in the policy rule WAN to Zywall is disabling my vpn connection when I disable it.
    So you need a rule for WAN to Zywall with service ports for the IPSEC VPN so you don't allow all service ports.
    You could do it as:
    first rule WAN to Zywall deny to service HTTPS
    second rule WAN to Zywall allow all
  • ictforever
    That did the trick. What also worked is to remove the https from the default group.
    Thanks @PeterUK
