usg20 creating multiple sessions
Need your thoughts/help here please. About a day after I installed usg20-vpn to replace my old usg20w, none of the client devices was able to connect to the internet. Logs showed that maximum session per host was exceeded. I disconnected all clients and even moved them to a different interface but logs were the same. Reboot and device reset didn't help either. What makes it interesting is, the logs were showing a destination IP (private) that does not exist on the network.
I put the old usg20w back and all worked fine again.
Hello epogi,
Would you please check do you tick"Enable Session Limit", if so, please disable it, and test it again.
Charlie0 -
I will give it a try. For now, do you know any reason why 1) it creates session on multiple IPs that are non-existent on my network, i.e. 10.0.2.x and 2) this doesn't happen on my old usg20w ?
Hello epogi,
After disable the session limit, does issue disappear?
If log display numerous message showing the same destination IP, you may check which client try to connect to that IP.
Go to session monitor to double check who try to connect the destination IP.
Charlie0
- 383 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 229 Switch FAQ
- 200 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
