zyWall 110 DHCP no intenet by WLAn
Kowalsky
Kowalsky Posts: 2 image  Freshman Member
edited April 2021 in Security
hello,
we use a ZyWall 110 V4.31 AAAA.0 2018-03-28 00:00:36.
The most of the PCs use a Fixed IP4. Only 30 DHCP cliens Access withe a Hotspot the Internet.
We get the messange the internet is not connet at androide. The DNS servers Fail.
Router lan 1 is at 192.168.112.2
DHCP Server
Ip Start pool 192.168.112.210 pool Size : 30
First DNS Server ZyWall
Defalut Router LAN 1 ip
Lease Time  15 min
some bose sound system at Static DHCP Tabel at range 192.168.112.70-80 withe MAC adress.
we try dns server WLAN 1, Coustem 8.8.8.8 we got at all the same problem.
at DNS Register : Adrress/ptr Recode : one Adress for Email client to local server
Domain Zone Forwader :
Domain Zone : *
Type : user-Definded
DNS Server : 8.8.8.8
Querry via : wlan1
somebody have a idea?
thx
kai
#Biz_Security_Feb_2019
  • Jeremylin
    Jeremylin Posts: 166 image  Master Member
    First Answer First Comment Third Anniversary
    Cannot the all client access internet with default DNS setting?
    Since your configuration is not too complex and firmware is previous version, I suggest you update the latest firmware and reconfigure it again.
  • Kowalsky
    the pcs withe stactic IPs have no problems.
