No-ip and access to hd by ftp
Genius19
I set on my Zyxel VMG8823-B50B no-ip service and I want to access from outside my home to my hd.
I registered to no-ip and I set parameter to router but I'm unable to access to hd by ftp.
I have to open any port on my Zyxel? How?
Regards
#CPE_Mar_2019
Regards
#CPE_Mar_2019
Can you check in Maintenance / Remote Management if ftp service is enabled in WAN?
I'm unable to see it. I known my provider sent me blocked router. I can't see all the menu voices.
Is there a way to see this menu by a code o something else?
Regards0 -
I had a similar problem:The firmware of the VMG8825-B50B modem is customized by Wind, but it was enough for me to understand that to answer me from the internet it was not my server from the PC but the modem that I found the solution. I changed the FTP port to enter the modem from 21 to 2121 and turn it on the internal LAN on port 21, at which point the server started working. I need the FTP client to remotely use port 2121 and thus coming in from the Internet the modem does not consider it an FTP service so it does not appropriate it but it changes it by changing the port and assigning it to port 21 and then making it FTP for my server.0
....but at least you can see ftp settings. With tiscali provider I can't.0
- 234 Nebula Ideas
- 6.7K Security
- 695 USG FLEX H Series
- 366 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 312 Service & License
- 510 News and Release
- 97 Security Advisories
- 5.1K FAQ
- 89 About Community
- 114 Security Highlight
