VMG8825 - PROBLEMA COLLEGAMENTO WIFI IPCAM
pakyvit
se qualcuno puo aiutarmi non riesco in nessun modo a far riconoscere la mia ipcam scsinocam al router 8825. viene riconosciuta e la vedo solo se collegata in LAN mentre non riesco a fargli prendere la pw wifi. come posso fare?
#SP_Apr_2019
#SP_Apr_2019
Hi, sorry that I don't know Italian, so I reply in English.
If the IPCAM support WPS, you can try to use WPS to connect the IPCAM to the router.
There should be a WPS button on the router, press the button could enable WPS for a few minutes.
You need also turn WPS function on the IPCAM within a few minutes to make the IPCAM and the router connected.
FYI0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
