GS1900-8HP PoE control via SNMP
I just received a new GS1900-8HP switch. While being able to turn PoE for individual ports on/off using the browser, setting this via SNMP does not work (using OID 1.3.6.1.2.1.105.1.1.1.3.1.1).
Does anyone know if/how this works with a GS1900-8HP?
Thanks!
#Biz_Apr_2019
#Biz_Apr_2019
ok, found it. should anyone else need it, the OID is
1.3.6.1.2.1.2.2.1.7.1
(for port 1)
so this was actually not the solution -- it just disabled the port, NOT PoE.
does anyone know of a way to control PoE via SNMP?
Hi @konrad
Unfortunately GS1900-8HP doesn't support POE on/off via SNMP given the fact it's our entry level switch.
You may have to switch PoE on/off via Web-GUI.
In addition, you may consider our higher level switch series, such as GS1920v2-8HP which can support the feature you desire.
Sincerely,
Zyxel_Lucious
- 3K Nebula
- 231 Nebula Ideas
- 6.6K Security
- 680 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 502 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
