GS1900-8HP PoE control via SNMP
konrad
konrad Posts: 3 image  Freshman Member
edited August 2022 in Switch
I just received a new GS1900-8HP switch. While being able to turn PoE for individual ports on/off using the browser, setting this via SNMP does not work (using OID 1.3.6.1.2.1.105.1.1.1.3.1.1).
Does anyone know if/how this works with a GS1900-8HP?
Thanks!
#Biz_Apr_2019
  • konrad
    ok, found it. should anyone else need it, the OID is
    1.3.6.1.2.1.2.2.1.7.1
    (for port 1)
  • konrad
    so this was actually not the solution -- it just disabled the port, NOT PoE.
    does anyone know of a way to control PoE via SNMP?
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 305 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    Hi @konrad
    Unfortunately GS1900-8HP doesn't support POE on/off via SNMP given the fact it's our entry level switch.
    You may have to switch PoE on/off via Web-GUI.
    In addition, you may consider our higher level switch series, such as GS1920v2-8HP which can support the feature you desire.
    Sincerely,
    Zyxel_Lucious
