How To Switch To 5GHZ (NWD6605)
Balint0227hun
Hi guys, so my ZyXEL NWD6605 just arrived and I absolutely have no idea on how to switch to 5GHZ... Could someone help me out here?
Thank you
#Others_May_2019
Thank you
#Others_May_2019
Hi Balint0227hun,
Basically, you don't need specifically switch to 5GHz. NWD6605 is a "Dual-Band" Wireless USB Adapter, it is support both 2.4GHz and 5GHz band, which means you should able to find 5GHz signal when you have installed NWD6605 in your computer/laptop.
Or you can change the setting of NWD6605 adapter which you wants. For Windows 10 path is, Control Panel > Network and Internet > Network Connections, you will see your NWD6605 adapter, then click on the right button of your mouse on its icon and choose "Properties" > "Configure..." > Advanced.
Preferred Band:
Wireless Mode:
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 635 USG FLEX H Series
- 356 Security Ideas
- 86 Switch Ideas
- 54 Wireless Ideas
- 301 Service & License
- 494 News and Release
- 93 Security Advisories
- 109 Security Highlight
