Restrict LAN access but allow internet USG20w-VPN
I have setup a basic L2TP using PSK and basic username/password and with the help of videos and documents from ZyXEL I have it all working. The VPN is handing out 192.168.50.xxx while the local network at the USg20w-vpn is handing out 192.168.1.xxx IP addresses. I want to allow internet access through the VPN but want to block access to the LAN at the server. To clarify if it isn't clear, if I connect to the VPN remotely, I do not want to access the local network at the server, I just want the internet to go through the VPN, but no access to the remote resources. I can configure these, but I am barely intermediate at best, I have no idea what to look for to do this. Does anyone have any tips on what I should do?
Also, when I setup the VPN I did it through the configuration wizard - it is pretty must the standard defaults for that setup type.
After setup VPN through the wizard.
You can add one firewall rule before the "IPSec_2_Any" rule to block the access.
On GUI, go to Security Policy > Policy Control, click add to add a firewall rule.
- 441 Beta Program
- 292 Service & License
