How to convert configuration from USG 300 to ZyWALL 1100?
mkr
mkr Posts: 6 image  Freshman Member
Friend Collector Fourth Anniversary
edited April 2021 in Security
a customer is using a USG 300 and wants to upgrade to a ZyWALL 1100. He does not use USG features but has a lot of policy and NAT rules, and VPN connections configured.
The online converter does not support USG 300 => ZyWALL 1100.
Is there a workaround or how should I migrate the configuration? I thought I will make the basic configuration by hand and then connect over SSH and paste the aliases and rules by hand. Is there a better way?
Thank you!
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @mkr
    To analyze this case, please private message your configuration to me.
    Charlie
  • Zyxel_Charlie
    @mkr
    I private message the modified configuration to you, so please check it.
    Charlie
