IPSec Site2Site VPN Performance - which is the best configuration?
lightskyblue
Hi there
We are using a IPSec Site2Site VPN.
At each site there is a Zyxel VPN300 with fiber wan (1Gbps/1Gpbs).
There are several options for IKE (IKEv1, IKEv2), Encryption (DES, 3DES, AES128, AES192, AES256), Authentication (MD5, SHA1, SHA256, SHA512) and also Perfect Forward Secrecy (DH1, DH2, DH5, DH14).
Are there some "best practises"?
Which is the best mix between security and performance?
What are your experiences?
Does the new VPN300 models have some special CPU support for some encryption methods?
Best regards
Best regards
@lightskyblue
The encryption/hashing algorithm should be chosen by users themselves. I think there is no so called “best practice” but more likely a tradeoff between “Security” and “Throughput”. If you use a complex algorithm to encrypt your data, it consumes the CPU and sure the throughput will be lower.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
