SecuExtender - Removing Previously Saved UserNames
Zyxel_Charlie
This discussion was created from comments split from: SecuExtender - Removing Previously Saved UserNames
Description:
Client cannot delete the previous usernames in the drop down menu.
Description:
Perhapse,
ZYXEL write a documentation, how to manage the SecureExtender by Windows policies to enable/disable possibilities for the Extender.
Regards
Christian
+1 I agree this 'feature' would be a worthwhile addition.
The ability to remove previously saved usernames/IP address is basic functionality (IMO) that should have been implemented from the beginning.
Okay, now I'm thinking one step further. Is there a documented possibility to configure the dialin parameter (vpn-server/server-list) trough policy, and remove the last logged on user to have a control about the VPN client configuration on business devices ?
Regards
Christian
btw, you can manually delete saved usernames/IP adress by editing (with Notepad++ eg) the SecuExtender.xml located in C:\Users\USERNAME\SecuExtender.xml1
- 603 USG FLEX H Series
- 481 News and Release
