GPON PMG5705-T10A in bridge mode
Antonello_L
Antonello_L Posts: 2 image  Freshman Member
edited November 2019 in Smart Home Product
Hi
I'm trying to use the router in subject as a bridge to share my fiber connection with a router connected to it via WAN port , but it doesn't work. I followed the manual with no success , i'm wondering if someone has done and wanna share a configuration like this .
Antonello
#SP_Nov_2019
  • Nikki
    Nikki Posts: 40
    First Comment First Answer Fifth Anniversary
    Hi Antonello,
    It might related to OLT setting which control by service provider. Suggest you to contact with service provider to get the help.
    Cheers.
  • Antonello_L
    Hi Nikki
    We've done the same with Genew model HG326AC successfully, with no changes on OLT ports , that's a lab environment, but i'll go deep in OLT settings as you suggest.
    regards
    Antonello
