Zyxel t50 and Express VPN ?
PixelNinja72
PixelNinja72 Posts: 2 image  Freshman Member
edited January 2020 in Smart Home Product
Hi,  Ive just received a new Zyxel T50 router from my internet provider, T-Mobile.   Unfortunately I have no clue how to configure it to use my expressvpn account.. The support at ExpressVPN had no clue either as there is very little documentation about it.  Any help please ?
#SP_Jan_2020
  • [Deleted User]
    [Deleted User] Posts: 213
    Hello @PixelNinja72,
    can you let me know the exact model number?
    Greetings
  • PixelNinja72
    Hi Skoob its a T50
  • wojtek_NL
    wojtek_NL Posts: 1 image  Freshman Member
    Hi, i have exactly the same problem model number   ZYXEL VMG8825-T50
  • Hummel
    Hummel Posts: 212
    image  Master Member
    As I know, you need to download ExpressVPN sotfware in your PC/Laptop so that you can use it. I think it should not be set in the router which you use to connect to the Internet.
