dashboard startup-config.conf last date modified
what time exactly does it say was the last date modified?
does the syslog event show any particular actions done on that time?0 -
Hi @DanZyw,
Did you save the configuration this morning?
The time of "Config last updated" will follow the last time you save the configuration.
Here is my screenshot:- Backup before saving the configuration
- Backup after saving the configuration
Hope it helps.
Jason0 - Backup before saving the configuration
also this morning the date has been updated so every morning i think there is something that autosave the file so this is the first 3 rows from startup-config.conf, i think that is not good to see modified date also when i dont' change nothing.
! saved at 2018-03-19 09:32:05
! model: ZyWALL 110
! firmware version: 4.30(AAAA.0)
! saved at 2018-03-21 09:32:04
! model: ZyWALL 110
Hi @DanZyw,
It seems like you meet the problem on ZyWALL 110.
For this case, @Zyxel_Charlie will help you for details, so this topic will be moved to Security Discussion Section.
Thanks.
Jason0 -
@DanZyw
If you active/inactivate the profile or making the connection(VPN) connected/disconnected or doing the packet captured on the device, USG will do save to current configuration.
Charlie0 -
Ok thank you very much, but is better update the date only when somebody change something. Best Regards.
- 588 USG FLEX H Series
- 477 News and Release
