USG110 logs unnecessary 'info: DHCPv6 receive solicit from....' entries
my USG110 log gets crowded with 'info DHCP DHCPv6 receive solicit from fe80:: ...' entries which are quite useless for me. Is there any other way to block these entries than in Configuration > Log & Report > Log Settings
> System log under network selecting dhcp logging to disable? With that I get rid of these IPv6 entries, but also of all IPv4 entries, which is a negative side-effect from my point of view as for debugging purposes I would like to have entries like 'Requested 192.168.1.139 from [mac-address]' and 'DHCP server assigned 192.168.1.139 to...' in the log.
Any ideas?
regards Possu
Any ideas?
regards Possu
@Possu
When you enable IPv6 function, the PC will send the solicit packet to USG.
I would like to know does any IPv6 in you environment? If no, please disable IPv6, so the message will not appear.
Charlie0 -
I have a fully functional IPv6 environment so disabling IPv6 is certainly not an option. I would just like to get rid of these useless messages which appear once a minute or so from different devices on my network.
Possu
@Possu
The current design of IPv6 is that the log message show the details of process of communication between PCs and USG.
If you want log message only display "result" for IPv6 communication, it does not support on USG Series so far. I will move this request to Ideas section.
Charlie0
- 434 Beta Program
- 2.6K Nebula
- 172 Nebula Ideas
- 404 USG FLEX H Series
- 296 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
