drop connection bank with firewall zywall 110
i want understand who drop connection with my bank while i surf the internal page, the drop some time happen after few second after the login and sometime after few minute after the login. I make a first rule to allow any to bank ip, but nothing changed. Also with all feature disabled UTM KAV ect... the connection drop with variable time, only without phisical firewall the connection is stable. For now i changed trunk without success, next trial is only with wan active and the other passive .
may be that this session control when traffic is very high drop my connection?
I had a similar issue on trunk with the Lead Load balancing First , had a PC that works hard with the Bank to bind to a specific ISP channel through policies.
the question is how understand who drop the connection! After we can decide what is better to change.
@DanZyw
Can you try to add the routing profile and monitor it again.
If the issue still occur, please private message the configuration for checking further.
Charlie1 -
DanZyw said:the question is how understand who drop the connection! After we can decide what is better to change.
the problem with bank has been solved by rule suggested from Zyxel_Charlie, now we have a stable connection with bank. Thank you very much!!! Best Regards.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 263 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
