dashboard startup-config.conf last date modified
DanZyw
DanZyw Posts: 10  Freshman Member
First Comment Nebula Gratitude
edited April 2021 in Security
last date modified in startup-config.con has been update to this morning, but i didntchange nothing. This is a bug!
  • CrazyTacos
    CrazyTacos Posts: 53  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    what time exactly does it say was the last date modified?
    does the syslog event show any particular actions done on that time?
  • JasonTsai
    JasonTsai Posts: 104  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Nebula
    edited March 2018
    Hi @DanZyw,
    Did you save the configuration this morning?
    The time of "Config last updated" will follow the last time you save the configuration.
    Here is my screenshot:
    • Backup before saving the configuration
    • Backup after saving the configuration
    Hope it helps.
    Jason
  • DanZyw
    also this morning the date has been updated so every morning i think there is something that autosave the file so this is the first 3 rows from startup-config.conf, i think that is not good to see modified date also when i dont' change nothing.
    ! saved at 2018-03-19 09:32:05
    ! model: ZyWALL 110
    ! firmware version: 4.30(AAAA.0)
    ! saved at 2018-03-21 09:32:04
    ! model: ZyWALL 110
  • JasonTsai
    Hi @DanZyw,
    It seems like you meet the problem on ZyWALL 110.
    For this case, @Zyxel_Charlie will help you for details, so this topic will be moved to Security Discussion Section.
    Thanks.
    Jason
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034  Zyxel Employee
    edited March 2018
    @DanZyw
    If you active/inactivate the profile or making the connection(VPN) connected/disconnected or doing the packet captured on the device, USG will do save to current configuration.
    Charlie
  • DanZyw
    Ok thank you very much, but is better update the date only when somebody change something. Best Regards.
