How do i change the time on my Aurora?
MrWolf
I changed timezone and now the time is wrong.
#Others_Apr_2020
#Others_Apr_2020
The timezone is correct but the time is wrong to be clear0
Where is your region? And firmware version?
Has screenshots?0 -
The timezone in Stockholm should be UTC+2, right?
It should be but it isn't in the settings as sweden. And even if I switch to utc +2 the time is wrong.0
How wrong is the time? How many hours late or early?
If I set the time as UTC+2, the camera time shows the time as I found on the website: https://time.is/UTC+2.
Can you provide some screenshots? and compare it with the actual timing.0 -
Around 3h and 11 minutes with UTC +20
You can try to reboot the CAM, will it make any change?0
I have tried to reboot and I have tried to reset it completely. Still doesn't work.0
This problem may relate to the NTP server has blocked by your Router.
What is the model of your Router? If it blocked the NTP port 123 by default, your CAM will not able to sync the time.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
