Can't manage to connect to L2TP/IPSec VPN in MacOS 10.13.3
carles
carles Posts: 5  Freshman Member
First Comment Seventh Anniversary
edited April 2021 in Security
After following the steps of this tutorial, I can't connect to my VPN.
The system tries to connect but, after a while, launches an error saying "the L2TP-VPN server dit  not respond".
I have no problem with Windows 7&10 clients.
  • Whiskey_Alpha
    Whiskey_Alpha Posts: 3  Freshman Member
    What are you seeing in the logs of the USG?
  • [Deleted User]
    [Deleted User] Posts: 118  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    Can you check  the config.. Please set the L2TP connection with a full dynamic config. This is not  seen in the KB article, but may help you.
    So in Fase 1: GATEWAY
    Then in Fase 2 (vpn connection)
    And  check again if there is multiple porposals set
    Hope this helps. Otherwise share your logging en set filter IKE
